Can't send or receive picture messages
Hi, I have a Sony Ericsson Experia Arc-S phone which I have recently-ish bought on O2, I can access the interet on the phhone but am unable to send or receive picture messages, I have downloaded the link a few times and accepted the settings fof picture messages but still cannot send or receive them.
Follow updates on this topic
Staff
Re: Can't send or receive picture messag
I've set up the picture messaging on my side on your account just allow about an hour or two for it to activate then retry for me.
Ok, thanks Michelle.
Hi Michelle, just to let you know that worked, thanks for your help.
I'm having the some problem I can't send or receive pictures messages on my Nokia N8, can you help please?!
Hero
Does Internet work on the phone?
I have the same problem.  Internet works fine but the picture messages cannot be sent or received....can you work your magic on my account too ?
Staff
Can you power off your phone for 20 minutes, then test your mms about 13:00.
Will do
Re: Can't send or receive picture messages
Hello,
have the same problem for the past couple of months with my Sony Ericsson Xperia Arc. I've spoken to at least five people in O2 shops (including two Gurus) as well as someone on Twitter and on the O2 Forum. They've all said the problem was fixed but a few hours later it's back the same as it was. If I try and send a picture message it says Queued for Sending and if I try to download a message that has been sent to me it says Download Unsuccessful. What can I do? I've recently spoken to a manager in Mary Street and he wanted to send the phone away for a week and give me a crappy Nokia in its place - he also asked me to back up all the info on my phone! I'm not happy with this as this is not my problem - O2 have dropped the ball here and it seems I am the only one being inconvenienced! Your help would be greatly appreciated!
Thanks,
Oliver
Staff
Hi Oliver,
Sorry to hear of the issues you're having with the mms.
Have you received the phone back yet from repair? Is the issue fixed?
Have they given you a sim card replacement at any time during the trips to the stores?
Hi Michelle,
I didn't give it to them for repair yet - very reluctant to do so as I need it (and in particular the ability to send and receive picture messages for work) and I really want the issue resolved without having to send away the phone. Yes, they gave me a SIM card replacement in the O2 shop on Grafton Street nearly two months ago. That seemed to work initially but then it all went wrong again.
Thanks,
Oliver
Staff
If it goes wrong again after the sim replacement then it could be an issue in the phone causing it to stop working. Once the account is set up here from our end there is nothing else we can do here I'm afraid.
The phone will have to be sent away for repair again.
I understand you are not happy with the phone offered for replacement to use while it's being repaired but this is all the store can give
That's very disappointing! As soon as my 18-month contract is up with O2 I'll be off... Hard to believe the customer is the one who loses out in all of this?!?
Thanks for your help!
Staff
I can understand why you feel this way. I'm sorry I can't offer you any help with this query
My sony xperia wont send or receive mms also my bluetooth is not working, i moved from vodafone over a week ago and have had nothing only problems since, my phone worked fine before that
If sony xperia play mms and bluetooth is not sorted by tomorrow noon I am porting back to vodafone, I moved to o2 because of the win back campagin they offer you 20 euro every month when you top up by 20, but its a load of crap like the o2 network, very disapointed, rubbish
Staff
Is this the same phone you were using on Vodafone?
Hi sorry if I am highjacking somebodys elses thread,as I cant find how to start a new topic.I recently received a new phone from Hong Kong, as a gift from my daughter.When I try to download the latest software needed from O2 site..I get the following message ....
Sending of settings has failed
MMS Phone no OTA support, this caused error code ERR_OTA_006
The phone is .. Manufacturer Specifications
General
  • CPU: MTK6252
  • 2G: GSM 850/900/1800/1900MHz
  • Waterproof: IP67 (submersible up to 1 meter under water)
  • Shock Resistant
  • 0.3 Megapixel Rear Camera
  • Bluetooth
  • Battery Size + Life: 1400mAH
  • Usage Time: 4.5 Hours
  • Battery standby: 320 Hours
  • Languages: French, Spanish, Portuguese, Italian, Czech, Finnish
Display
  • Display size: 2.2 Inch
  • Display resolution: 176x220
  • Non Touchscreen Display
Memory
  • Internal: 64MB
  • Micro SD card up to 32GB
Media Formats:
  • Video: MP4, 3GP, AVI
  • Audio: MP3
  • Picture: JPG, BMP, GIF
Ports
  • 2x SIM card slot - GSM
  • Micro SD card slot
Any ideas how I can manually update same.
Cheers and thanks in advance for any help or feed back .
http://download.chinavasion.com/download/CVVB-M294-N1.pdf
The above is the manual..which is very basic .
