cancel
Did you mean:
3plus password reset problem
Not applicable
When I try to reset the password via the website it says there is a problem with the pin. Have tried it with 3 pins now same problem each time.
Re: 3plus password reset problem
Hi, I can  check this. Can you send me a PM with your number, address and date of birth?
