@EthanDonegal Hi there 👋 I've popped your post over to our Android section so other Android users can see it. Let's take a look at this for you and first things first - have you checked out our Re: All about: Phone Coverage blog? There are some really good tips and tricks over there along with a list of questions I'll need the answers to in order to get the ball rolling. Check it out and let me know 👌
Possible its a software issue, enable 4G only
and see if that helps.
also take the latest firmware update for your phone
@EthanDonegal I see some great suggestions here from @billbond4 and thanks for trying those! Have you taken a look at the article I linked above? If so let me know the answers to the questions listed in it! Also, how did you get on trying your partner's SIM in your phone? Are they noticing the same things you are with their phone/SIM?
@EthanDonegal That is very weird. Your data roaming was working but your national roaming wasn't/ isn't working? Let's take a step back, you first mentioned that your data connection would drop while visiting certain websites or using certain apps. I take it this is while you are in Donegal? Both you and @billbond4 have called out some good points, but have you cleared the history on your browser and uninstalled re-installed the apps? Have you ever experienced drops in data connection before? I'd love to keep this on the public forum, but I need the location where the data drops. Can you PM me your full name, number, address and date of birth?
