Help finding PIN
Bartosz
Newbie
Help finding PIN
Hi, I've been using the same phone for ages and I've recenty gotten a new one, I put my sim card in and suddenly it asked for a code, so I'm hoping for some help getting it.
Thanks.
LauraH
@Bartosz Hi there 👋 That's something I can help with 💪 Your PIN is generally related to your SIM card if you haven't set a PIN on your phone yet. It would be on the packaging of your SIM if you still have it. If not, pop me a PM with your phone number, full name, address, date of birth along with 2 numbers that you've called or text over the last 7 days and we'll go from there 😃
