cancel
Did you mean:
3G signal strength issues from mast at Glenfarne, Leitrim
Hi, since some bad weather a couple of weeks ago, our signal strength from the mast at Glenfarne, Co. Leitrim has reduced from 30-40% down to 6-7%.  The connection is therefore very hit and miss and when we do manage to connect, very slow.  Can I register a fault with this mast.  For previous issues with the mast, just search posts for Glenfarne.  Thanks, Matt
Tags (3)
Re: 3G signal strength issues from mast at Glenfarne, Leitri
Hi Mods, any chance of a response on this one? I'm currently paying for a service which is non-existant. Regards, Matt
Tags (1)
