cancel
Did you mean:
Data Only plan
Not applicable
Data Only plan
I am hoping to get a dual sim phone. I already have a plan that I like at the minute which doesn't have data. Is there any plan thatbonly has data which I could use for second sim only for data? Thanks in advance
Re: Data Only plan
Hi Ross, if you like I can check here about getting a data bundle added to your number, if you need to use the internet in your phone. Pop me a PM with your account info and I'll be able to help you here. Can you send the PM to ThreeContactMod. Thanks, Linda.
