Help With B525
Dave1345
Help With B525
Looking for some help if possible.
Have a Huawai B525 for home broadband.
Works fantastic for all things wirelessly however when I hardwire some things to the router it simply won’t recognise them.
Example, we have smart lights in the living room that are connected wirelessly and work flawlessly however with a hub for connecting smart blinds, this needs to be hardwired. When I wire it directly to the router, it simply will not recognise it.
If I wire the home PC directly to the router using the same cable, the PC works fine.
Another example, if I hard-wire a TP Link Plug And Play Switch to the box, nothing but again, using the same cable, directly to the PC and it is flawless.
Any suggestions or assistance appericated
Dave
Three_Danni
Hi Dave 👋 Let's check this out when you connect the smart blinds are you receiving any error message?
