Public IP and connection issues for remote access to CCTV
Not applicable
Hi, I have set up new broadband sim and requested Public IP with port access for remotely logging to cctv. so far I cannot get connected. Can you check this and help me please.
5 REPLIES 5
Not applicable
What is the APN you're using? Have you changed the APN and is it definitely a Broadband SIM?
Not applicable
Hi, I am using 'open.internet.public' and have tried 'open.internet' and '3internet' no joy with any of them
Not applicable
Yeah the open is the right APN. Did Three make changes on your account when you contacted them?
Not applicable
Yes, I have been in contact with technical team, they are investigating, so just waiting for reply. Thanks
Not applicable
Ah okay cool.i read on another forum that you need to make sure your modem/router is updated with latest software update. While your waiting you could give it a go
