what router and outside antenna can i use with three 4G
novicfps
hello everyone
could anyone tell me what router ( around 100 euro, cost ) i could use with a poynting 4G-XPOL-A0001 cross polarised 4G Omni LTE antenna. The router  i need should be able to place anywhere, around 7 or 8 metres from the antenna ,and sim card used with it also have 2.5 GHZ and 5GHZ bandwith. i have three 4G BROADBAND also have WPS.
3 REPLIES 3
Three_Deborah
@novicfps Hi there and welcome to 3Community. I'd love to help you out here but we don't support external antenna. But other members might have some advise in this aspect.
@BCrow @billbond4
billbond4
OK, as with anything to do with Radio Signals there are loads of variables.
So how far are you away from your nearest mast?
What type of house is your home?
Sometimes you could be within a few kms but there is a lot of users on the same mast so there wouldn't be a lot of bandwidth to spread around.
You could be better off by setting up your existing 3 router pointing at the mast then setup a mesh network in your house.
