Block It
Block It is a free service that allows you to block certain numbers from texting you. Block It blocks all texts, pictures and video messages from the number. You also won't be able to send any messages to this number.
How to use Block It
- To get started, just text BLOCK IT START to 50216.
- To block a number, just text the word BLOCK and the number to 50216.
Below is a list of all the Block It keywords:
Service
Keyword
To get started
BLOCK IT START
Block a number
BLOCK [and the number]
Unblock a number
UNBLOCK [and the number]
Check which numbers you've blocked
BLOCK IT LIST
Get the full list of keywords
BLOCK IT HELP
Stop this service
BLOCK IT STOP
Limitations
- You can't block Directory Enquiry or Premium Rate numbers. These are messages which come from a five digit number beginning with 5.
- You also can't block numbers from calling you.
