cancel
Did you mean:
4g promo and current data plan
Not applicable
hi I came over from O2 and have a plan for 2g of data. With the 4g offer does that now mean I have 7g of data. Also can I tether my tablet to use the data, I can with my 2g.
Anthony
2 ACCEPTED SOLUTIONS
3 Staff
Re: 4g promo and current data plan
With your plan you have 2GB's this does not change.
Yes you can use the 4G network once you are in a 4G area.
Any other queries let me know.
Not applicable
Hi Lisa thanks for clarifying that I don't know where I came up with the 5 gigabytes of data
4 REPLIES 4
3 Staff
Hi antheg,
Your data allowance remains the same with your plan.
You get 4G the network not 4 extra GB's.
Have you tethered with your data before? Everything remains the same as before with 4G.
Not applicable
Hi Lisa I thought part of the 4 g promotion you get 5 gigabyte 4g data.
So are you saying I can use 4g but only have 2 gigabytes of data.
3 Staff
Not applicable
