Call barring
Member
Call barring
How do I find 'call barring password' ?
@Antonio Ah, I understand! If you haven't changed the barring password yourself the general preset ones are 0000, 00000, 1234 or 12345. Give those a go and let me know how you get on.
5 REPLIES 5
@Antonio Hi there 👋 Tell me, when exactly are you being asked for this password? Have you set this password on your phone previously? Let me know and we'll go from there 👍
Hiya, I accidently signed up for something UK based and I am getting calls from them now. I blocked 4-5 numbers so far so I thought I would block UK calls to end it. It looks like it can not be done on android at least.
Thanks very much. 🙂
@Antonio No problem at all, we're always happy to help 😁
