I can't receive text messages from Polish networks: Orange, Play
I can send texts but noting comes back.
They can call me, but their texts are not coming through.
It all used to work and all of the sudden it stopped.
I tried my sim card in different device and it didn't work either.
Could anyone help me with this issue?
Regards
Hey morote,
I'll check this out for you. Is it all Polish numbers you can't receive texts from or just these networks?
Hi Joolz
I tried again with Polish Play network and it worked.
So it's only Polish Orange network I can't get texts from.
It's been like that for over two months now...
My smscentre number is set to +353868002000
Thanks for this info Morote, I'm checking into this for you at the mo 👍 Can you pop me a PM with your number and details? Can you send on a number you're not receiving these texts from also?
