Prepay call forwarding
Not applicable
Hi there, all the posts about call forwarding are 5 years old.
Its the restriction on the call forwarding for prepay only to voicemail still on, or we can change the numbers to forward to a custom one?
6 REPLIES 6
Not applicable
Hi dandna,
You can divert your number to another number to a voicemail if you'd like. Is there aspecificc number you want to divert to?
Not applicable
Hi, I neeed to set the call forwarding when unreachable (not busy or unanswered) to a diffrent number, not voicemail, but i cannot do it either via phone settings or GSM codes messages.
Not applicable
Dial **61* the number you want to divert to # To cancel this Dial ##61# and press call to cancel.
Not applicable
Tried already, get  a message "Call Forwarding Connection problem or invalid MMI code"
Not applicable
Can you PM me your details and the number you'd like to divert to please?
Not applicable
To close the thread, no, isnt posible for Prepay.
Move to other network seems to be the solution.
