My webtext allowance did not update on February 23 as the page said it should! Page now says it will go back to 500 in late March. I have recently topped up.
Webtext is clunky enough without this!
Appreciate herlp asp.
Hi @Anonymous I'll certainly look into this for you. Can you PM me your full name, number, address, and date of birth please and I'll check this out? If possible, can you take a screenshot of what you're seeing when you PM me also 👍
Hi Shauna
Thanks for your reply.
Screenshot from tonight attached. The number should have reset on Feb
23, according to earlier pages.
I am
******** Post edited ***********
Thanks,
Mike
>>>>>Hi bainin,
Three_Shauna (3 Moderator) mentioned you in a post! Join the
conversation below:
Re: Webtext allowance not resetting
you PM me also 👍
Reply | Accept as Solution | Like it
3Community
@Anonymous Hi there, I edited your post for your security, as it had your personal details. Can you send me a PM with your name, number, full address and date of birth? You'll see "send me a PM" under our post. Click on that 👍
Perfect, we'll get back to you there shortly.
Hi @Anonymous I'm just after double checking and I can't see you PM. Can you click '' send me a PM '' under my signature with your name, number, address, and date of birth of birth, please? This PM will then be sent directly to me 😊
Can you send me another private message please with the details above and I'll look into this straight away for you?
