cancel
Did you mean:
Webtext not working
Webtext not working
Tried this morning and also this afternoon, just getting "server error" message
Tried my smart phone and PC
Guide
Re: Webtext not working
Hi guys, I have just received an update from our tech team about this. When you log into your webtexts now you will receive an option to import your contacts. When you select “yes” your contacts will be updated.
48 REPLIES 48
Hi there,
Are you able to access the webtext platform today? We’re aware that some customer are getting this error and we’re working to restore the service as soon as possible.
nope tried it again this morning, still the same, this is poor from Three
3 Staff
Our technical team are working on getting this back up and running as soon as possible. We hope to have this resolved soon.
I am wondering will the webtext service be up and running again soon, (it comes up ERROR SOMETHING BAD HAS HAPPENED)
3 Staff
Hi JD 👋 Our technical team are aware of this affecting customers and are working on getting this resolved as quickly as possible. I haven't been given a time frame on this.
Hi martin
Thanks for your reply I hope its is up and running soon
been like this all weekend, very slow response to this issue
Smiley Sad
It consistently has been looking for security codes - every time I have used it recently.
It still seems to be down
3 Staff
Hi Guys, are you still receiving the security code message this morning?
