Iphone 5c showing Searching and Network Not found
Not applicable
Hi, The status on the top left corner of my Iphone 5C shows searching instead of the usual 3 and 3G/4G identifier.  When I go into Settings/General/About, the Network shows Not available.  I have tried all the online troubleshooting tips, network reset, factory reset, remove and re-insert SIM, power off and on to no avail.  Can someone help please?
Hi @Anonymous, is this happening to you in one area or many locations?
4 REPLIES 4
Martin
3 Staff
Hi Ongardude 👋 Can you give me your full address so I can look into this for you? Is this happening to you everywhere or just in one area and do you know if other customers in the area are also experiencing this? How long do you have your current SIM card and have you been able to test this SIM in another device?
Not applicable
I'm having the same issue...my data isn't working and people finding it difficult to ring me can't get through...I can't make calls or texts...only thing working is wifi
Not applicable
Hi, you can close this query as I got a new phone since, thanks!
