The irish Three SIM will not data roam in Poland (outside of ireland) with this Y33S vivo. (The same sim works fine in moto g9 power in poland ).
This phone is popular in Poland and i bought as dead phone replacement emergency. However Three support were unable to either tell me whether this phone is supported or get it to roam for data on Polish networks.Many hours wasted with Three techs on this. I have tried to use this phone in Switzerland (not in the EU) and data roaming worked fine. Data roaming also works fine in Ireland.
Either change mobile data provider or do not buy/attempt to use this phone for data in Poland. (It works fine for 2G voice and sms txt calls).
Details of the mobile phone that will not work with EU data roaming enabled, in poland, using an irish three sIM:
vivio y33s
runs a version of android from the chinese manufacturer: funtouch os 12
model:v2109
hardware versino: mp_0.1
build number pd2147gf_ex_a_36.15.2
baseband version: moly.lr12a.r3.mp.v136.6.p147
kernel version: 4.14.186-gb3e05a2ce-dirty
@ctgarvey As you are able to use data roaming using your other phone and are only experiencing difficulties with your Vivo phone. I would suggest double-checking your phone settings to ensure there's no block preventing the phone from connecting. As this is not a phone we currently support I suggest you link in with the manufacturer for more trouble shooting?
THree techs got me to check /modify many things around mobile network including;
sim preferences
roaming
preferred newtork type
network/automatically select network.
THey never suggested editing the APN whose settings are as follows (and these settings work fine in poland using motog9 phone with bill pay three ireland sim)
APN: 3ireland.ie
proxy:not set
port:not set
username:not set
passwrod:not set
server:not set
mmsc:http://mms.um.3ireland.ie:10021/mmsc
mmsproxy: mms.3ireland.ie
mmsport:8799
mcc:272
mnc:05
authentication type:none
APN type: default,mms, supl
APN protocol: ipv4
APN roaming protocol: ipv4
bearer: unspecified
MVNO type: none
i note there are some differences between these settings listed on three webpage and the setting in my phone (that works)
And this is why i asked 3 support the simple question 'Do you support vivio y33s for three data while roaming?'
And the response i got was 'i dont know'.
However you have cleared that up by stating 'this is not a phone we currently support'.
I created this community thread so that other people will be aware of this issue with the vivo & three incompatibility
Here is the entire equally unhelpful chat transcript from vivo y33s support:
Especially now that money is linked to your SIM, if your phone fails when you are abroad, then you are in trouble because the local replacement phone may not work. Therefore travel with a spare phone of IDENTICAL type to your working THREE phone. I would pay extra for a more competent service if one existed. Sadly not.
Thank you for your relationship with vivo customer service
i bought your phone in poland. My sim provider is THREE, Ireland. EU Data roaming does not work in Poland with the vivo y33s. It works ok in ireland
If you need a consultant's help, please click here
Please select the category corresponding to your question. A customer service consultant will be assigned to your case
After-sales consultation
Pre-sales consultation
We are glad that we could help
We're here for you. Describe your case in detail so that we can help you better.
Good morning
hello.
Good morning
i raised this issue with my provider THREE. They dont know why it will not work but says it is not supported. full details are on the community thread that i created here:
https://community.three.ie/t5/Android-Devices/Three-EU-data-roaming-does-not-work-with-Vivo-Y33S-Fun...
Please give me a while for veryfication
15:50
would you be able to find out please, why your phone Y33S does not work with THREE EU roaming data ? i had to stop using vivo and now use moto again
Automatic configuration may not work
2G / phone calls worked fine when in another country
You can check the apn settings manually
*#225# you can type this on your phone
we changed all the apn settings as per the THREE team recommendation and it still did not work. So let me rephrase the question;
and send us a screenshot
Do you know if anyone using THREE provider has ever successfully configred EU roaming data such that they have data access in a country that is not their home country?
ok this will take about 10 minutes as i need to remove sim from one phone and put it in another. and then start it. d you want me to do that?
No, we do not have that case previously
There was no report for such issue
with which service you are connecting by roaming?
i would guess that no one ever tried to use yss3 on THREE data roaming before. Because THREE themselves say that your phone is not supported
15:56
Okey
please can you raise case with your support team to find out how to configure y33s to work with THREE network (EU data roaming - outside the country of origin)
Vivo devices are not part of Irish market
yes i know that. but my phone failed and i was not in ireland. i was in poland
right now with motog phone (that works) i have following settings:
Do you set same settings as on motog in vivo?
mobile network: 3
preferred network type: 4G
roaming:connect to data services when roaming
automatically select network is: selected
access point names:
3 3ireland.ie
4G+ right now
Can you say what is the option of Roaming in the settings?
i attempeted to use same settings on vivo
16:01
roaming: connect to data services when roaming (as stated above)
https://community.three.ie/t5/Mobile-Broadband-Internet/Mobile-Internet-and-MMS-Settings/ta-p/519247
Can you check the settings which I sent?
settings are the same on the motog and were the same onthe vivo
I sent to you settings of apn to check
they are from three website
yes i checked them
and these are the settings we used when i was working with THREE technician
Check Settings->Network&Intrnet->Sim card & Mobile Network -> Sim 1 -> Roaming
i will put the sim in y33s now
Access point names are the settings of APN
I want you to check Roaming which option you have
There should be all networks set
standby please while i put sim in y33s
16:07
I am waiting
Take your time
phone boots
okey
only R service
Check the apn once again for each card
sim card and mobile netowrk: access data using mobile network
There is the difference for each card
as It is written on three website
please confirm what you mean be each card
As it is written on three website
cards are different
one thing i do note. the phone keeps using 3G and keeps connecting to plus. i am trying to choose network manually (i have been through this routine a number of times with different techs)
so THREE does not appear as an option
are you talking about 'SIM' cards ?
I understand
16:12
Yes, as a three said on website, cards are different
my phone number **** is not listed in the three article you mention, but i am using the working settings from motog
In depends which you have you need to set specific settings of apn
It depends of sim card numbers
We suggest check the apn settings depending on which sim card you posses
Then try to maybe connect to other settings manually
16:18
there was 1 difference regarding authenticaiton.
article calls for PAP, but my phone was blank
Okey, if you change then check if it helps
ive changed it.doesnt seem to have made any difference. but there is no THREE network displaying
if not try to connect manually
Three name will not display because this net do not access in Poland
there will be Plus, Play etc
We suggest visit your service provider in Ireland to check the settings with Three assistant
i cant connect to any 3g or 4g service manually
..except for phone calls. no data
We are very sorry, but we did not test three cards in our devices
We can suggest buying prepaid sim card from polish service provider for temporary solutions
16:23
it looks like that even to see the available networks on the vivio, i have to select 'automatically select network' : on
then i can choose one. but none of them enable data
Okey
ok so back to my original question. can you raise a ticket please with your 2ndline/3rd line team to find out if it is even possible for THREE SIMs in y33s. then you can publish the results
Yes we collect feedback to our R&D center
We will analyze this case with our engineers
great thank you
For now I suggested you some temporary solutions like buying prepaid card from polish service provider
End service and rate
No file chosen
p
not a solution - revolut is tied to a unique phone number.
thanks for these.... will try I am in Portugal and data does not work on phone.
Hi @Jimmy007, have you got sorted with roaming in Poland? If not, can you advise what difficulties you are experiencing, along with what networks are showing when you do a manual network search and I am happy to support. Dearbhaile
