call barring
Not applicable
call barring
my phone wont let me call internationaly it says that it is barred.
when i go to deactivate it it says i need  a password??
Not applicable
Can you power off your handset and try now.
24 REPLIES 24
Not applicable
Not applicable
I have the same problem: I can't make international calls: call barring and I need a pass.
Thank you
Not applicable
Can you power off you handset also, the bar will be off then.
Not applicable
Thank you
Is working now
Regards
Not applicable
Great thanks
Not applicable
Same problem with me, phone doesn't allow any international calls.
Not applicable
If you restart your phone and give it a go now it should work for you lilleke80
Not applicable
Thanks a lot!
Not applicable
Same problem here, could you please help me as well?
Regards
