Getting ready for U-Know!
Landline Call Forwarding
Call Forwarding allows you to forward your calls to any other number in Ireland, either fixed or mobile.
You never need to miss a call again, as it can be transferred to whatever number you can be reliably contacted at.
All PSTN (public switched telephone network) customers can be provided with Call Forwarding.
You must have a touch-tone phone (push-button telephone) to use the service.
If you are using an internal phone system, then this service may not work.
There is no recurring or set up charge for this service. You are charged each time you set up the service (25 cent). All calls are charged according to your price plan.
Setup instructions:
Setup Call Forwarding
*21*Telephone No#
Cancel Call Forwarding
#21#
Variable Call Forwarding needs to be enabled on your line. To get Call Forwarding provisioned on your line:
  • Call Three Technical Service Desk on 1800-800-002 and press option 1.
