Gateway and Route for static ip
phoex_hatim
I have got business plan and a static IP.
The static IP works well with the router. However, I want to assign that IP address to a server rather than to the main router. I am looking for gateway route information for that static ip so that I can configure that in my server.
I rang three tech support but not much luck. Three tech support said they were not trained for this type of configuration.
I am not sure if this is possible at all with Three static IP?
Cheers!
7 REPLIES 7
Hi @phoex_hatim thanks for reaching out to us here on 3Community.
I'll be honest I'm not sure if this is possible either, but I've reached out to our technical and network teams to find out for you. As soon as I get an update I'll respond here 👍
Hi @Three_Stacey ,
Thank you for your reply.
Did you get a chance to talk to your technical / network team?
Regards,
Hatim
@phoex_hatim I've reached out to the teams and at the moment I'm still waiting for a response. I do expect that to be in the next day or two but in the meantime, I'll follow up and see if I can hurry it up.
@phoex_hatim thank you for allowing me the time to look into this for you and I'm sorry it took so long. I've just received confirmation from our teams that at the moment applying a static IP to a server rather than to the router is not something that we are able to provide at the moment.
Hi @Three_Stacey ,
Thank you for the updates.
Is there any option for requesting additional public IP address and then set that as server IP?
@phoex_hatim Sorry but the only option available is the static IP assigned to your router.
Hi @Three_Stacey ,
Ahh alright. No problem.
Thank you for your help so far.
I will have to check with another service provide in this case.
Regards,
Hatim
