4G and Wi-Fi Calling
What is 4G calling?
4G calling is exactly as it sounds – voice calls over the 4G network, instead of the 2G or 3G network, which we use normally. On a 2G or 3G network, calls and data are separated and can’t work at the same time. For example, during a phone call on a 2G network, any incoming text message will only arrive after you have terminated your phone call. On a 4G network, both calls and data work in unison, meaning that a text message will arrive instantly, even during a call!
Why do you need this?
4G calling is the premium of voice calls. By using 4G instead of 3G or 2G, you will get a stronger, richer, faster connection. Did you know 4G calls can be connected up to twice as fast as before?
Also, you can now call on 2G, 3G and 4G, giving your calls a great coverage range. With this added bonus, you will now be able multi-task… browse the web while downloading or making that important call! And if all that wasn’t enough, your phone will have an improved battery life.
Will there be extra charges for 4G calling?
No, 4G calling is a free service, with the calls being deducted from your plan allowances, the same as before. Your minutes will continue to be consumed by calls that you make. Once all voice minutes are consumed, out-of-bundle charges are applicable.
What do you need?
You will need a 4G compatible device; no other app or add-on is needed! Your phone must be within the range of a 4G/LTE network. You will need to activate the 4G calling in the phone's settings:
iOS – 15:
Tap Settings > Tap Mobile Data > Tap Mobile Data Options > Tap Voice and Data > Ensure the 4G Calling slider is in the “on” position.
Android:
Tap Settings > Tap Network & Internet > Tap Call > Tap to enable 4G Calling/HD Voice/Enhanced calling
How will I know if I am on VoLTE service?
For Android users: The “HD/VoLTE” icon will be shown on the top bar of the screen.
For iOS users: There is no visual change. However, you can verify the VoLTE status using the steps we have outlined above.
Back to top.
Wi-Fi Calling
What is Wi-Fi calling?
Wi-Fi calling allows you to make and receive calls using available Wi-Fi networks - so if you are at home and you find you have coverage issues indoors, you can make and receive calls over your home Wifi connection instead. This is a built-in feature on most smartphones - follow the instructions below to check if you have this enabled in your smartphone settings. No additional apps or add-ons are needed for this, so once it's been enabled in settings, you just use your phone as normal to make and receive calls.
Please keep in mind that the quality of Wi-Fi calls will depend on the quality of the Wi-Fi connection.
Android
Open the ‘Phone’ app.
Select ‘More’, then ‘Settings’. 
Select ‘Calls’. 
Select ‘Wi-Fi calling’. If you don’t see this option, it may be because your device doesn’t support this feature.
iPhone
Go to Settings > Mobile Data > Wi-Fi Calling.
Turn on ‘Wi-Fi Calling on This iPhone'.
Will there be extra charges?
Not at all! Wi-Fi calling uses up call minutes included in your plan, but you wont have to pay anything extra to use it.
FAQs:
When will 4G calling and Wi-Fi calling be available for me?
Not all devices will be compatible at launch (August 2022), but keep an eye on our devices page by clicking here, for a list of devices available for Wi-Fi calling, or click here for a list of devices available for 4G calling. Once it’s available for your phone, it will be updated.
Will I be notified once it’s available?
Yes, when 4G and Wi-Fi calling becomes available, you will receive an SMS to notify you.
I have activated 4G calling & Wi-Fi calling, so what's next?
Nothing. Once you have activated the service in your phone settings, you are all set-up and good to go.
Is my device compatible?
With the launch of 4G and Wi-Fi calling, not all phones will be able to use the service right away. Click here to see the list of current devices compatible with Wi-Fi Calling. Over the next few months, more devices will be added, so keep an eye on the list. NOTE: iPhone Wi-Fi calling isn’t currently available but don't worry, as we are working with Apple to get this up and running as soon as possible.
Why isn’t 4G calling or Wi-Fi calling not working for me?
If you have a compatible phone and your phone has the latest software, click here to speak with our Messaging team to make sure that your account is set up correctly.
Back to top.
What are the T&Cs for 4G & Wi-Fi calling?
Click here to read the T&Cs for Wi-Fi calling.
Click here to read the T&Cs for 4G calling.
Contributors
