Dial your mobile number with a 5 after the prefix from a landline or another mobile to access your Voicemail. E.g., If your number is 0861234567 you would dial 08651234567.
Interrupt your greeting by pressing the # key.
Enter your Voicemail password followed by the # key again.
The default Voicemail password is 0000. You can change this by dialling 173 from your phone.
You may be charged more than usual to call your Voicemail when you are abroad. You may also be charged if someone leaves you a message. Learn more about voicemail charges while roaming by selecting your plan on the Price Guide to get all the details.
Do you need more support?
Why not ask the 3Community and benefit from the experience of over 90,000 members.
