Getting ready for U-Know!
How to Disable Pop-Up Blockers when using Live Chat
The following describes how to disable pop-up blockers on the most popular internet browsers:
Please note that if you wish to use Live Chat on three.ie, you must first disable your pop-up blocker.
Google Chrome
  • Click on the WRENCH icon (this may also appear as three dots, but it is always on upper right-hand corner).
  • Click on SETTINGS.
  • Scroll to PRIVACY and security.
  • Click on Site settings.
  • Scroll down to Content and select Pop-ups.
  • Click OK.
Firefox
Windows
  • Select Settings.
  • Select Privacy & Security.
  • Scroll to Permissions.
  • To disable all pop-ups, uncheck the Block pop-up windows radio button.
  • Select Close.
Mac
  • Click Firefox.
  • Click Preferences.
  • Select Content.
  • Un-check Block pop-up windows.
 Safari
  • Click Safari in the menu bar.
  • Navigate to Websites - Pop-up windows.
  • Uncheck the box next to Block pop-up windows.
Edge
  • In Edge, go to Settings and Cookies and site permissions
  • Select Pop-up and redirects.
  • Turn on the Block
