Mobile Internet and MMS Settings
Three Mobile Internet and MMS Settings
If you are having issues accessing the internet or sending picture messages (MMS) on your smartphone, you may need to update the settings on your phone. We have provided general instructions below on how to update your internet settings. You can also visit our Device Support area, select your device and follow the step-by-step tutorials.
Your settings will be slightly different depending on if your SIM card number starts with 8935302 or 8935305. The below info is for smartphone settings only.
Android or iPhone Settings
Settings for 8935302 SIM card numbers
Android iPhone
These are usually found under:
  • Settings
  • Connections
  • Mobile networks
  • Access Point Names
APN: internet
Proxy: leave blank
Port: leave blank
Username: blank
Password: blank
Server: blank
MMS Proxy: 62.40.32.40
MMS Port : 8080
MMS Protocol : WAP 2.0
MCC : 272
MNC : 02
Authentication Type : PAP
  • Settings
  • Mobile Data
  • Mobile Data Network
Cellular Data
APN: internet
Username: blank
Password: blank
MMS
APN: internet
Username: blank
Password: blank
MMC Port: 8080
MMS Max Message Size: 307200
MMS UA Prof URL: blank
For device specific settings, and to view a step-by-step tutorial on updating your settings, go to Device Support.
Settings for 8935305 SIM card numbers
Android iPhone
  • Settings
  • Connections
  • Mobile networks
APN: 3ireland.ie
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC: http://mms.um.3ireland.ie:/mmsc/
MMS Proxy: mms.3ireland.ie
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 272
MNC: 05
APN Type: not set
  • Settings
  • Mobile Data
Mobile Data
APN: 3Ireland.ie
Username: blank
Password: blank
MMS
APN: 3Ireland.ie
Username: blank
Password: blank
MMS Proxy: mms.3ireland.ie:8799
APN: 3ireland.ie
If you have updated your internet settings and are still having issues accessing the internet, click here to view our troubleshooting article.
Do you need more help? Why not ask the 3Community and benefit from the experience of over 90,000 members.
