Roaming issues
Chris_59693
Roaming issues
Hey all,
I am currently in greece and have major roaming issues. My phone does connect to a network (nova) but drops every few minutes for a good 10-30 seconds.
The bars keep on showing up with the R and full bars (4 on my s24)
It is likely not a network issues as my partner stays connected (albeit to a different network operator, cosmote)
I tried switching manually to either cosmote or Vodafone, but all it does is telling me that is unable to connect.
Correct me if I am wrong but from what I understand I should be able to connect to any operator when abroad and be able to eat up my dara allowance.
What could be the cause for this issue and how do I fix it? It's very annoying, especially when I see my partner not having any issues at all.
Best regards,
Chris
Chris_59693
Chris_59693
