Call Barring Removal
Not applicable
up until recently I was able to text & ring my brother in NZ on my Nokia 520 but all of a sudden messaged stopped getting trhough and now I can't ring either - my tells me to check my Barring setting but I don't have anything blocked .  Please help as this is urgent.
28 REPLIES 28
Not applicable
I did and no I don't have another sim to try
Not applicable
I will post you another sim card and we test it is that ok?
Not applicable
Thank you, as long as it will have the same number, will it ?
Not applicable
Yes you will, I will post it now.
There is no block on your account for sms to an international number. we will test the sim if you could also maybe test your sim in another O2 phone if you get the chance to do this.
Not applicable
received new sim today, thank you.  Registered it and it is up & running but still unable to txt NZ..  will my old sim still be able to work in my husbands phone to enable me to check that ?
Not applicable
No your old sim won#t work, try the new sim in your husbands phone thanks.
If it persists I will have to send it to our technicians.
Not applicable
Forgot to mention that he can txt me but doesn't receive my reply, so it's not only txts initiating from this end 😞
Not applicable
Ok I have to send this to our technicians can you PM the number you are trying to text and the network are they are thanks.
Not applicable
Just tried new sim in my husbands phone and txt failed 😞 and this time i typed in the number rather than used stored number 😞
Not applicable
I don't have an option to pm you direct 😞
