NoIP / DynDNS
Highlighted
NoIP / DynDNS
I'm trying to set up remote access to a 4g router using NoIP / DynDNS that has a 3sim installed.
My problem is that the 3 sim card seems to be giving me 2 IPs
The public IP available at whatismyip.com doesn't match the IP address that I can see assigned to the sim card.
Both IPs ends with the same numbers, but the others are different. (I'm not talking about the internal LAN IPs)
I hope the above makes sense, can anyone assist me?
Highlighted
Re: NoIP / DynDNS
@KMac Sounds like you're looking for Public IP access. Due to recent changes on our network, the application of a Public IP is currently unavailable. Our tech team is aware of this and working to find a solution. We will update you when we have a timeframe for this and I apologise for the inconvenience. Please send me a PM with your details, that way I'll be able to follow up with you in the future 👍
