Just wondering does my local phone mast have 5G?
The coordinates are:
Site ID: THREE_LO0008
Easting: 303457
Northing: 307340
Latitude: 54.01
Longitude: -6.42
Info taken from the Comreg Site Viewer.
Thanks.
Thanks Stacey. Do you know are there any plans to upgrade this mast to 5G? Thanks.
@SeanMac I've taken another look at the coverage in your area. ComReg doesn't have 5G service listed yet but I can see that we do currently 5G in your area. To avail of the service, you'll need to make sure that your phone is 5G enabled & that the plan you're on is 5G compatible. If you let me know the name of your plan I can check if it's compatible.
