@Chrishaines Hi there, I get where you are coming from and I've checked our Planned Works blog for more info click here I see that Dunboyne is on the list. Works start today and I'd expect them to continue until at least tomorrow. I'm happy to check back in with you.
@Chrishaines I've had a look the mast for you and see that the 3G and 4G maintenance has been completed for the day. You might have to power off/on your router. What our tech team does now, is monitor the signal ramp up to make sure that everything is in working order. At this moment, I can't say that the planned works are completely over and won't run into tomorrow, as that is based on the findings from the ramp up.
