Public IP
Rita_07017
Public IP
I'm writing to get a dynamic public IP enabled for my 3Broadband Unlimited 5G as I'd like to use a device that needs one. Thanks.
Kind regards,
Rita
6 REPLIES 6
LauraH
@Rita_07017 Good morning, let me check to see if this service is available on your plan! I'll be back as soon as I know for sure 👍
@Rita_07017 Apologies for the delay on this. We're currently looking into it, as soon as I have news I'll let you know.
No problem & thanks for looking into it. Just to clarify I'm looking for a public IP address for my router the same as this post: https://community.three.ie/t5/Broadband/Public-IP/td-p/774738
@Rita_07017 I understand 👍 At present this service is only available on certain plans as per this thread over here 👉 click here. I'm looking into the availability on 5G plans for you 👌
I've just discovered that my VoIP phone works without the need for a public IP. So I don't need one after all. 😳 Apologies for any inconvenience caused.
Kind regards,
Rita
@Rita_07017 Great news Rita and thanks so much for reaching out and letting us know 😃
