- Mark as New
- Bookmark
- Subscribe to updates
- Mute
- Subscribe to RSS Feed
- Permalink
- Email to a Friend
- Report this post
Balance not rolling over. €20 being removed every month.
Hi all
Can anyone tell me why / when Three started to remove €20 from PrePay plans every month?
It used to be a case that you would top up by €20 Euro and this would roll over. But now €20 is being deducted from my balance every month.
This was despite not altering a plan/account at all.
E
- Mark as New
- Bookmark
- Mute
- Permalink
- Email to a Friend
- Report this post
@eladnova Hi there, our new suite of plans deduct the top-up straight away to activate the new allowances. the €20 plan is called 3 Prepay 20. Can you check your My3 and see if you are on this plan?
If your plan is 3 Prepay, which is now a legacy plan and no longer available to new customers or when you change plan, then your €20 top-up carries over but there are t/c's for when your credit expires. Also, credit can be depleted quickly if your plan expires, as data is €1.01 per MB.
Let me know.
