Getting ready for U-Know!
Three+ Cinema
Hollywood blockbusters, action, thrillers, and comedies – I love them all. If this sounds like you, then why not check out Three+ 2 tickets for €10?
What is 2 tickets for €10?
All Three+  customers can get 2 cinema tickets for €10 in any IMC cinema Sunday – Thursday. All you need to do is redeem a code from the Three+ website or app, and off you go. This offer is available at IMC cinemas nationwide.
How to get your code
  1. Log in to Three+ via the app or website.
  2. Select Cinema.
  3. Select your local cinema (If you don’t see your local cinema, try the search function on the right of the page).
  4. Click Redeem code via web or SMS on the website, or click Use it now.
  5. Your unique code will be sent to you by SMS, or it will appear on screen.
How to use your code
It's really easy! Simply redeem your unique Three+ code and show it to staff at the cinema box office. Or book in advance online at www.IMCCinemas.ie
Do you have any questions about Three+ cinema codes? Don’t forget to check out the Terms and Conditions or pop over to our forum to start a topic by clicking here.
Contributors
