Hi All
I am hoping someone can help
I recently completed construction of our dream home. Upon building the home I was using my phone regularly to contact suppliers and builders etc and had no issue at all making calls. However, on completion and when the house was sealed up with windows in and foil backed cladding and roof materials, I was shocked at how bad the signal is internally now. Both myself and my wife work from home and this is hugely affecting my business. I done some research online and it is a mine field of information on boosting signal with self install signal boosters and I am worried about compliance. I checked both the comreg site and Ofcom site in the UK and it turns out that the following booster seems to be legal and compliant https://mobilesignalsolutions.co.uk/product-category/signal-boosters/
I just wanted to check if anybody has had any experience with these boosters. It seems this brand Huaptec
are the best reading reviews and the company Mobile Signal Solutions have brilliant reviews also
Hoping to get some advice and help
Col
Hey @Colin_58205 thanks for posting here, I wouldn't be able to recommend the above product as they aren't a product that we sell or provide support so I couldn't advise on whether they would work in your situation.
In a situation like this I would recommend that you have WiFi Calling turned on your device which can help improve the signal when you are connected to WiFi in a house.
