Is there any solution to change NAT 3 type to 2 on Samsung Flip 4?
Playstation Portal requires NAT type 2 or 1.
Hey @Stan_666 , Welcome to the 3Community 🙂
Thanks for posting your query here, we have received some queries about console devices and being automatically connected to NAT Type 3, while I can understand your frustration as soon as I have an update I will pop back here to you.
Would using a vpn help?
Hey @billbond4, thanks for commenting on this thread. When it comes to hot-spotting and tethering, these are device features so unfortunately, we wouldn't be able to guarantee how these will work when connected to other services or also we wouldn't be able to recommend if using a VPN could help the query.
Has there been any update here?
Hey @SCrowley thanks for messaging here, unfortunately as the hotspot is a device feature I wouldn't be able to guarantee that the Playstation Portal is going to work with this. If this is a NAT Type issue you can try setting the Hotspot APN to open.internet however I cannot guarantee this will resolve this for you.
Did you manage to find a solution?
Hey @Add_93691, I'd love to have a look into your query for you, pop through to me here on PM along with your full name, broadband number, address and date of birth so I can check the account for you.
