hiya I have an iPhone 11 and for the best two months I haven’t been able to receive incoming calls all of my calls are going straight to voicemail and then I get a text saying I missed a call. I have checked all my settings and nothing is wrong there I have received calls but only when I’m connected to my car then I get the calls but no other times
@Add_10113 Hi there, have you noticed any issues with your texts or data services? To do a quick test call you dial ##002#, this will turn off your voicemail. Once you've got that done can you ask someone to call you & see if the call still goes to voicemail? If the call shows for you then there's a voicemail setting that's re-directing your calls immediately. If not, then we'll need to investigate further. Let me know if it works for you.
Hiya, sorry for the late response. So I actually can’t send text messages either although since turning off my VoiceMail I can now receive calls no problem but I don’t actually want my VoiceMail to be off I would like for it to be on
Hi @Add_10113 👋 To activate your voicemail you just need to call 171. Have a look at our blog All About: Voicemail for step by step guide on setting up and using voicemail. If this is not working for you let me know what's happening.
Tell me more about the difficulties you're having with your texts. Is this all texts or just texts to a specific number? Do you get an error? Are you able to receive texts? Let me know so we can see what our next steps should be.
Hi, I was receiving texts but just couldn’t send them but now I am not receiving texts. I can receive calls but I can’t Seem to turn on my voicemail. I tried calling 171 but there wasn’t an option to turn it back on.
Hi @Add_10113 thanks for all the details. The next thing we need to do is review your account. Please PM us your name, number, full address, and date of birth.
