I have a 3Business Broadband Max service and I would like to obtain a public IP address on my connection.
I contacted Three Technical Support, and they advised me to try the following APNs:
However, with both APNs, my modem is still being assigned a private WAN IP address in the 10.67.x.x range. This indicates that the connection is still operating behind CG-NAT.
I believe that an additional service or configuration may need to be enabled on the SIM card or account before the public APN can assign a public IP address.
Could someone from Three please review the provisioning of my service and confirm what needs to be enabled?
I only require a public IP address. It does not need to be static.
Thank you.
Hey @cyber_business thanks for posting here, if you pop through to me on PM along with your full name, broadband number, address and date of birth I'd be happy to to have a look for you or alternatively you can speak to our broadband team on 1913.
Hey @cyber_business I can see that you have sent me a PM and I will respond to you there.
