ZTE T3000 Custom DNS for DHCP Clients
Gerry_67566
Developer
Hi All, trying to set a custom DNS server (pi-hole) for DHCP clients on the T3000 but in DHCP there does not seem to be any option for setting DNS servers. Does anyone know if there's an advanced config section I might be missing?
many thanks.
3 REPLIES 3
Hey @Gerry_67566 , thanks for posting here on the Community, when you are logged into the Device dashboard are you able to view the Advanced Settings section on the bottom of the home screen? This can be accessed by entering the IP address at the bottom of the router and once you have logged in you can view the DCHP settings.
Hi, thanks for the reply. I got to those setting alright but the only realy thing you can change is the DHCP scope/ range, I didn't see any option to configure what DNS servers were set, was hoping maybe there was an advanced->advanced menu I was missing?
Thanks Gerry, I assume that as you are using a ZTE T3000, you are on a 5G Broadband Gold Plan where the external router is installed by a technician, can I confirm are you using the IP Address  192.168.254.1 so you can access the dashboard of the device, the password and username will be on the power adapter on the internal device.
