I am using a 15 euro package, I will go to Europe next month
Merve_22bjk
Hi @Merve_22bjk and welcome to 3Community👋
If you're heading off to Europe I'm guessing you want to know about your roaming allowances, all you need to do is click here and select your plan. In our price guide, you'll be able to see what roaming allowance is included in your plan.
To check the roaming rates while you're abroad just click here and enter your mobile number and your destination. It'll display on screen the roaming costs for your plan while in that country.
I'd also suggest having a read of our roaming blogs before you leave for some tips and tricks which may come in handy while you're abroad.
All About: Roaming
All About: Roaming with Three
Let me know if there is anything else that I can help you with 😊
