5G plan with a 4G phone
Dan_14051
I'm hoping to switch to one of the 5G prepay plans, but my phone isn't 5G compatible. Will my 4G usage be included also?
3 REPLIES 3
Hi @Dan_14051 thanks for reaching out to us here on 3Community 😊
The answer to your question is Yes. If you're on 3 Prepay 15, 3 Prepay 20 or 3 Prepay 30 and you activate the plan you'll have access to 4G.
Thanks for the reply, and is that All You Can Eat 4g?
Yes, @Dan_14051 if you're on 3 Prepay 20 or 30 once you top up and activate the plan you'll have all you can eat data. I suggest having a look at our blog All about: All You Can Eat Data with Three Prepay it'll give you a lot of details.
