Service Unavailable
Three.ie is currently unavailable so you cannot Sign In, but you can continue to search & read content on 3Community.
Top up 40 and get 20
Arka_16795
5 REPLIES 5
Three_Shane1
@Arka_16795 Hi there & welcome to the 3Community 👋 It looks like you're on our Prepay 20 plan. With this plan if you top up by €20, your account will be debited €20 to activate your plan. Since you topped up by €40, €20 was taken for your plan activation & remainder was left on your account as part of your balance.
Thanks for the answer, but no, it been activated up to 21 of August. (as you can see from screenshot 25 of Jul I paid for 4 week)
Whenever you top-up by your plan amount which in your case is €20 your plan is activated. This is why you only see a balance of €20 out of the €40 top-up you did.
It was already activated. 25 of July, after 9 days I top up my balance for 40 and got 20. You can see it from my screenshot.
Whenever you top-up by your plan amount regardless of when your last top-up was the system will register this as a plan activation. For example, if you topped up on 09/08 by €20, your plan would be activated. If the next day on 10/08 you then topped up by €40, €20 would be taken to activate your plan allowance & the remaining would be added to your account as credit. If you wish to add a credit to your number going forward I would suggest topping up by €10 or €15.
