Regifting tickets
anangray
Regifting tickets
I won tickets to a concert last week, still haven't received them but I can't make the concert myself. Can I regift the tickets to someone else?
Thanks!
No problem @anangray I can see you have PM'd me there so let's get this sorted for you.
10 REPLIES 10
Hey @anangray, Welcome to the 3Community 🙂 I can check here to see if this is possible, pop through to us here on PM along with your full name and mobile number and I can check this with the team.
As you're new to the Community you'll need to increase your rank to send PMs. You can increase your rank by commenting on posts, creating new posts, & kudos/liking comments. Once you rank up you'll get a message to notify you & you'll need to log out & back into the Community & you'll be able to PM us directly.
My man, I've better things to do than create unnecessary posts and comments. I'll just contact Three a different way, cheers
Hey @anangray I can see here you should have access to PM's so if you change your mind pop back with your details and I can check this for you.
Knew you'd come through Niall, sent you a PM 😀
Mandy_56945
Developer
Did you get to regift them, I wanted to do this and was told under not allowed? Also on completion was ment to get a hoody and gift pack but the concierge knew nothing about it, so disappointed.
Hiya,
They said this to me-
Thanks Kristiana, so to answer your question no I can't transfer the prize however you would be able to transfer the tickets yourself.
A week before the event you will receive an email from Three Ticketing to RSVP that you are going to attend the event. When you fill in this form all you need to do is enter the details of the two people attending instead of yourself and then their names will be on the guest list when they arrive at the venue.''
Hope this helps!
Hiya,
I have the same issue and i just got the RSVP  there that I accepted but it did not ask me for any details just whether it was 1 or 2 guests?
Can you clarify?
Hey @Anu , thanks for posting here. With Three+ competitions  the prize would be for a pair of tickets. When you receive the RSVP this would only be sent to the competition winner however this would be the RSVP for both tickets and your name will be on the guestlist for 2 tickets.
