I am on a Prepay plan and top up €20 monthly. However over time my balance has grown quite a bit and I wanted to know whether if I did not top up for the next month or 2, could I just try and use up my balance and then once it has reduced down I could start topping up again and reactivate the plan?
Someone suggested that if I do not top up that I immeadiatly lose all my balance, but that sounds odd, so wanted to confirm.
@Add_96195 Hi there & welcome to the 3Community.
I would suggest first checking out our blog How To: Buy apps using 3Pay for ways to spend your prepay credit.
If you leave your plan to expire your credit will be used on all calls, texts, & data until it reaches 0. Data usage outside of your plan can be quite expensive so your credit can run out very quickly. If this is the route you wish to go down I would suggest turning off your mobile data before your plan expires so this doesn't occur.
If you have any further questions let me know 😊
