Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
103 REPLIES 103
Hi @Three_Niall, attempted to PM you to no avail regarding the same issue as above.
NAT is strict on both ZTE and my shared hotspot. Both worked fine for the first 2-3 months. Port forwarding, using APN, disabling DMZ and factory reset does absolutely nothing.
Can you please provide a bit of insight or a potential fix for this?
Any help would be much appreciated.
Hey @Phil_14831 , I can see here that you have sent us a PM and we will continue to help you there.
Hi Niall, just trying to get in touch with you about the type 3 NAT. Just hoping you can help configure the APN settings for my device. Would appreciate if you could get in touch with me.
Hey @Diarmaid_67758 . I can see here you have contacted us via PM and we'll help you there.
Just spent money on a game I can't play because the NAT type is "strict". I am not paying a cancellation for the bricking of my net that the customer service did
 It's insane that I'm still having problems.
Hi there, I'd love to look into this further for you, pop through to us here on PM along with your full name, mobile number, address and date of birth so I can check this out for you.
Hi Jamie,
I'm having the same issue with a nintendo switch console. Just off the phone with customer support who had me login to my router settings and switch off my 5g with a toggle but I have no such setting. Can you assist me.
Hey @Enda_46163 I can see here that you have sent me a PM so I am going to check the account here for you.
Hey @Enda_46163 I'm so glad we could get this sorted for you in PM 👍 Don't forget to hit the Accept As Solution button.
If anyone else is experiencing similar pop through to us here on PM.
Hi Niall,
Unfortunately I'm having the same strict NAT issue i experienced last year with my Xbox. I checked the router settings and the apn that worked before is still there. Is there something else I need to do now to get it to work again? Thanks.
