Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
104 REPLIES 104
Same and I need to supposedly spam engagement on the forums to even ask a question via pm. The girl on the phone told me I need to throttle my speeds to 4g to even get to NAT 2 which is in direct violation of my consumer rights as both Gaming and High Speeds were advertised.. I have to sacrifice high speeds to game??
Hey @Nat3onthree I can see here that you have sent us a PM so I'll be happy to help you here.
To answer your question, to remove the NAT Type 3 from your console you wouldn't need to move to 4G/3G. Depending on your device the IP address you will be asked to use will be different and once we have the device type we will send on the steps to update the APN on your device however we need to make sure everything is set up on the account for this to work. To answer the above question it isn't a case that you would need to "throttle" your speeds as you have advised but I will respond to your PM and we can check your account.
I have the same issue here and the broadband customer care were adamant it wasn’t an issue they could solve? I would be very grateful for some assistance
Hey @Shane_03787  , Welcome to the 3Community 🙂
I am unsure why you were advised that this wasn't an issue that could be resolved however I can see that you contacted us here on PM and I will help you with your query there as it requires me asking for personal information we would never request on a public forum.
Yeah they told me there was no way to fix it without going from 5g to 3g which is pretty wild. The DM process is taking a few days unfortunately.
Hey @Nat3onthree I can see here that you responded to my reply when we were closed however I will respond to your PM now 🙂
@soceal wrote:
@Padraig_46186 wrote:
Anyone else unable to find the APN option? I have looked up videos online and it seems where most have settings where the APN should be, but I have one saying Dynamic IP without the APN option
Use this link and it should help:
https://www.three.ie/device-support/device/zte/mc801a/topic/settings/how-to-set-up-a-static-ip-addre...
So the problem with this fix is while it does bring you to NAT 2 - it kills your downloads to Ps5 once they pass about 2 gigabytes. I've seen one thread on this and the guy who made it said that the help team told him that they don't have a fix yet. This means for NAT 2 currently I can no longer download anything over 2gb until it throttles and stops entirely for 10 to 15 minutes then repeats. Hopefully they have a fix??
Hi Niall,
I am having the same issue as everyone above.
i have tried to pm you bit it says access denied.
does it take long to be able to level up to pm you?
Hi Niall,
Would you mind sharing the settings to avoid the Nat type 3?
I'm trying to lv up to send you a private message but I'm unsure how that works.
Thanks!
Hey @Giulio_46041 , I can see that you have messaged me here via private message and I will be happy to help you there.
