Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
Hey everyone, thanks for your patience on this and I appreciate your patience in allowing me to look into this further. Unfortunately, I don't have an update on this query currently. As of now, I don't have troubleshooting steps that I can provide to help resolve this however the networks team are actively working on a solution to this and as soon as I have this I will be popping back here on this thread.
106 REPLIES 106
Hey @Derek_43295 , Welcome to the 3Community 🙂
Before you complete troubleshooting on the device would recommend doing a factory reset and this will set the device to the default setting including the APN settings. On the bottom of the device, there will be a small hole with the word reset written above the device. you will need something small like a pin and push down the button and once you feel the click and hold it down for 10 seconds.
Once you have completed this factory reset I would recommend checking the user manual for steps to enable UPnP as you are describing and if this is unavailable I would recommend checking if your router requires an update.
Hi Niall
Factory reset has already been done on the device.
Several times.
Again. Issue isnt the device.
Its the fact the carrier is using Carrer Grade NAT on the APN .. so no matter what i do with firewall.. or dmz... port fordwarding .. Upnp.. It doenst matter..
Factory rest done.
Ip address given to xbox 192.168.0.61
Logged into web interface for ZTE.
Since reset. Upnp is off and closed.
Enabled. Apply Sucessful..
Restart router to be sure.
Xbox also restarted.....
Upnp still blocked on xbox after reboot...
Dmz then enabled.. ... and ip address applied..
Xbox then rebooted again....
Still the same... Strict..
Wait.. Lets try and turn off Firewall fully...........
ohhh look... still the same....
So again.. i will ask for the APN settings for a fully open and not one with NAT 's already applied.
Can you provide these..
Or show me the settings on a router.. that should show it.. how its applied.. in what steps and ill test that... BUT again... I know this will be blocked...
Again.. its NOT the xbox or the Zte router...
Xbox put on eircom wired fibre connection... Open.. No Nat issues..
Just to say.. Also tested in Bridge mode...
And i hope you understand what that means..
The xbox connected to the router in bridge mode.. Is passed the WAN ip address .. all firewall is turned off on the router..
And yet...
Same results.. NATS are strict..
Can some one advise like i asked at the start..
What is the Open APN.. that has NO natting at all on it please.
Thanks Derek, can you pop through to me here on PM along with your broadband number, name, address and date of birth and I can check the account here for you so that I can better advise on getting this resolved?
Pm Sent to you there with Details.
Just to prove again. Its network settings been blocked on the router...
If i do a look up on .. Whatsmyip ...
Which should show my external ip 🙂 yes...
Ip is 80.233.49.103
BUT if i go to the device and look at the WAN ip... SHould be the same.. If i have a public IP and not a shared ip .. BUT wait..
i have an ip on the wan of
10.52.17.103
So again.. Ill ask for the APN details of a NON Carrier Grade NAT APN ..
The Default on the router WAS this... BUT this has changed in the last 2 weeks.
This is why the NAT and port forwading isnt working and also the DMZ... as the CG Nat is blocking it..
Also if you want to just do a port test on port 88 and the Whats my IP.. you will see its blocked..
Which its not...
its just you cant test the port when its sharing ip with several other users.
Please dont ask me to restart the router. ...
25 years working in IT.
Derek,
Did you get this issue resolved? I'm having the same issue.
John
Hi John
I SORT of did for a while..
i found.. if the router restarts.. it will always revert back to strick..
What i had to do .. was...
On the xbox... Run a nat test.. At the same time.. on the web interface of the zte.. Turn off the NAT... and turn it back on again while it was testing..
This worked for about 2 weeks..
But now.. Back to Strick all the time.. even if i try the same method that did work for me..
its the double nattin that is casuing the issue...
NAT issue here too...
