Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
104 REPLIES 104
Hey @Pierre_51077  , Welcome to the 3Community 🙂
I can see here that you have contacted us on PM and I will continue to help you there and gather more details from you also.
Robin_88991
Hey, have you gotten anywhere with Three in getting this resolved? I've been having the same issue on PlayStation since about October. They sent me a whole new antenna and router but the problem persists so it's definitely on their end.
No joy. They say they're investigating it still. I'll have to go back to fixed line broadband if they can't fix it even though it's significantly slower
That's disgraceful. They told me the same and that I'd hear back about the case within days. That never happened and when I phoned to ask for an update I was told no issue had been found and that I should upgrade my hardware instead. The connection had been working perfectly fine for over a year, then they flipped a switch somewhere and now none of their customers can play online anymore. And their customer service reps don't have any knowledge of it so it's pointless to contact them.
Hey @Robin_88991, I have raised this with the relevant team when we received contacts on the above and we have a team investigating into this further however I have received your PM and I will look into the specifics of your query there.
I'm having the same issue with the router on my PS5. I have not found anything on the router options, when I contacted the customer support they have told me to contact Sony, I explained that it was and issue with the router and not Sony, just for the time I contacted them and....surprise is the router and not Sony, did anyone found a solution?
Three customer service reps don't have the level of knowledge or access required to do anything about this. It's the same on every device (I have a PS5 and a Switch, strict NAT on both). NAT type is determined by the ISP, it might sometimes be helped with port forwarding and the like, but this is a non-starter in this case as Three has implemented a network-wide change without notifying its customers or briefing its customer service reps. It represents a degradation in service and the silent treatment people on here have been receiving for months now is infuriating. I'm looking into cancelling for breach of contract at this stage. I can only recommend to keep contacting them and demanding a solution, as only a critical number of escalations to their engineers is likely to be noticed.
Thank you for the very helpful feedback!
Hey @Randolfato, Welcome to the 3Community 🙂
Thanks for your message, I have raised these examples with the network teams who are continuing to investigate this further. While I don't have an update on when this will be resolved I can assure you that the team is continuing to investigate this further.
If you have raised a case with the technical team previously and would like me to add it to the list I have passed onto the team or if you would like me to check the account / raise a case for you pop through to me here on PM along with your broadband number, full name, address and date of birth and I can do this for you.
Guest_69833
I have this same problem  support not help at all I return my 5g  to three  next week I'm on 14 days trial I call them 8 times in lot 4 days.NOT RECOMMENDED
