Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
106 REPLIES 106
Hey @Stephen_49298, thanks for posting here, I can see you have sent us a PM and I'll be happy to help you there.
Hi Nial
im trying to pm you however it says access denied
i have a ZTE 3 router on a prepaid sim, it was on open nat untill today could you assist
Hey @Ettas36  , thanks for posting here, I have checked this for you and you should now have access to PM me here, pop through to me here on PM along with your full name, mobile number, address and date of birth and I can check this here for you.
Hi @Three_Niall
I believe that I have this issue also, but am unable to PM you. Could you help me with this?
Hey @MP64 thanks for posting here, I have checked this for you and I can see you have access to PM or alternatively if you contact our dedicated broadband Team on 1913 they can get this sorted for you.
Similar issue, double Nat causing issues on PC virtual desktop. Cant pm as yet.
Hey @Brendan_38499 , thanks for posting here, if you are unable to PM I would recommend contacting our dedicated broadband team on 1913 who can get this sorted for you.
