Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
104 REPLIES 104
Pm sent
Fix worked for me , NAT type 2 on ps5 and type B  on switch
Pm sent
hi niall pm sent 🙂
Hi Anthony, only finished work and seen this, is it a simple fix on their side or do we have to do it ourselves ?
Unless they did something on their end, only thing I had to do was to change APN to: "open.internet.public".
I put that in there to test it but still pops up strict, is there a certain IPV I should put it as, and the authentication?
Try restarting the router and the console! That fixed it for me
No, I just changed the APN and rebooted both outside unit and inside WiFi and my NAT changed to 2/B (PS and Nintendo)
This actually worked! From strict and double Nat it went to moderate. Double Nat message is gone too
