Derek_43295
Same issue..
3ireland.ie
3internet
3broadband.ie
internet
open.internet
open.internet.public
three.ie
104 REPLIES 104
Anyone else unable to find the APN option? I have looked up videos online and it seems where most have settings where the APN should be, but I have one saying Dynamic IP without the APN option
Use this link and it should help:
https://www.three.ie/device-support/device/zte/mc801a/topic/settings/how-to-set-up-a-static-ip-addre...
I've changed the ipv to open the one suggested and I am getting Nat Type B on xbox and Switch but I've tried connected online to my daughters Mario kart ( on the switch ) and its still complaining about the nat type and wont allow me to play online. anyone else getting this ??? ( I've tested the nat type again and its back to D)
Do I use my default gateway from my router, or 192.168.0.1
Hey Everyone, I can see a few people have messaged me via PM and I will be getting back to you this morning now that we are back online.
For anyone who is having issues please pop through to me here on PM and I can get this resolved for you. To answer the question last night, you will need to contact me via PM to get this resolved as I will need to check to make sure that everything is set up correctly on the account before you apply the APN. You can view how to change the APN on your Device Support guide however once you contact me via PM and I can confirm everything is set up I can then send you the steps based on the device you are using.
Thank you Niall it worked for me so happy, and also thank you for being so supportive even when we all were a slight bit frustrated you are very good, thank you
Hey @Add_88835 , delighted to hear that the fix has worked for you and appreciate your patience 🙂
Hi Niall, I'm having the same issue as the few users here. For some reason I'm unable to PM you as it says access denied. I would appreciate it if you could help me out as well. Many thanks in advance.
Hey @Orlos, Welcome to the 3Community 🙂
I can see that you have since been able to send me a PM so I will reply to you there to get this sorted.
I am not able to send pm either. HTML error and then limit of messages reached
